Boujou To Maya Frame Mismatch
COW Forums : Autodesk Maya
Josh Wibberley
on Aug 16, 2015 at 2:31:31 pm
I have tracked an object Using boujou(The move type is static camera moving scene) and imported the data into maya. But everytime in import it the frame range in maya changes to 0.4-69.2, When it should range from 1-73. The sequence that I tracked was at 59.94 FPS.
I need help!
Thankyou :)
