Maya alpha channel issue
COW Forums : Autodesk Maya
Dmitry Orlov
on Aug 6, 2015 at 1:32:21 pm
So, how to delete these "black borders"? How to use alpha channel to delete them?
Seung Yoon
Re: Maya alpha channel issue
on Sep 3, 2015 at 6:17:42 pm
Does that texture map have an alpha channel in it?
to check, open the texture in Photoshop, and click on Channels Menu (usually next to the Layers Menu) and see if your texture comes with a alpha channel.
If not you have to create a Alpha Map.
if it does, Do not save in JPEG because that wont save out the alpha channel. Save as .png or .TIFF instead
hope that helps
cheers
Seung Yoon
