Maya 2015 create cube or any surface question
COW Forums : Autodesk Maya
Dominik Lončar
on Apr 4, 2015 at 12:23:43 pm
Hello,
Im relatively new to maya and this forum. Have maya for one week, but now have got one problem. I was experimenting with maya windows a bit and then restored settings in window -> settings/preferences -> preferences -> edit -> restore default settings. Now when i create cube or any other thing, its faces are separated objects.
Is it supposed to be like that with surfaces? It works normal with polygon cube.
George Sears
Re: Maya 2015 create cube or any surface question
on Apr 8, 2015 at 5:47:30 pm
Hi Dominik,
I never use Nurbs surfaces, so I had to check Maya myself; yes, Nurbs Cubes are always separate objects, all in a single group (same with Nurbs Squares.)
I'm sure Nurbs surfaces can have their uses these days, but I would stick with Polygons.
Kill me again; I dare you!
Dominik Lončar
on Apr 8, 2015 at 8:56:27 pm
Thanks George,
I thought i messed something up. Yeah I'm gonna stick with polygons cause there's no reason for using NURBS.
Eric Santiago
on Apr 9, 2015 at 1:19:09 pm
There are so many reasons why we use NURBS.
Im not going into details with this other than please try and learn some of it least.
It will do you good :)
Dominik Lončar
on Apr 9, 2015 at 4:05:34 pm
Ok, I'll learn basics of surfaces. But I really don't see any point of it for now. Looked on other sites and if I'm not wrong, its like old version of displaying models, kinda slower? You create curves and from curves mesh? But why wouldn't you just use polygons and if you want it smooth, then use soft selection?
Eric Santiago
on Apr 10, 2015 at 2:37:27 pm
Up to you.
Just from experience that Polys isnt all there is when it comes to modeling.
Dominik Lončar
on Apr 10, 2015 at 3:55:21 pm
Ok thanks, I'll have that in mind.
