Glow reduction/removal in transparent areas while saving .png (Maya)
COW Forums : Autodesk Maya
Mohammed Hanafy
on Mar 11, 2015 at 10:19:46 am
I tried to search for a similar issue and I couldn't find, I even asked this questions in places and got no answer so far, hopefully someone can help...
When I render a scene with an object that has a glow then save it as .PNG to put it later on a background using Adobe Photoshop, the glow effect get reduced in a very bad way, I tried to search for a similar issue but I couldn't find even a close one...
Check the next picture to get a better image of what I'm trying to do.
If I saved the rendered Image as .JPG I get the glow exactly as I wanted and seen in the rendering view, but if I saved it .PNG then added a black background behind it, the glow get reduced and almost removed.
What cause this issue to happen? and how can I overcome it?
