Bright outline when rendering objects
COW Forums : Autodesk Maya
Jeremy Haccoun
on Feb 19, 2015 at 7:14:51 am
Hello,
I have a question about rendering objects in Maya 2013/VRay, for compositing in After FX. I'm working on a scene with my models in front of a sky background.
When I import my VRay render in After Effects, I set the Alpha to "Premultiplied/Matted" so as to display the objects alone, but then I have a bright outline on all objects rendered. I have to apply filters in AFX, matte chokers, etc to get rid of this outline, which messes with the original edge of the object, especially when it's a small object such as a ladder.
Do you know where this bright outline comes from, and is there a way to render objects without it?
Eric Santiago
Re: Bright outline when rendering objects
on Feb 19, 2015 at 3:02:24 pm
Can you place a background matte and render to see if its within Render view?
It does sound like a premult issue.
Jeremy Haccoun
on Feb 20, 2015 at 11:58:40 pm
Thanks Eric - can you elaborate a little? What do you mean by background matte?
Eric Santiago
on Feb 23, 2015 at 1:27:05 pm
During Import into AE have you tried Straight as an option?
And in Maya there is not background matte of any sort right?
Even a camera with Image Plane.
Jeremy Haccoun
on Feb 23, 2015 at 2:49:50 pm
Yes, tried both straight & premult in AE, same issue.
In Maya I have a camera image plane but it's turned off, and I have a VRay Sky behind my objects
