why does UV Texture Editor not show the image?
COW Forums : Autodesk Maya
HongWei Li
on Jan 9, 2015 at 3:55:37 pm
Hi , everyone .
When i use mia_material_x , the UV Texture Editor doesn't show my UV
like is :
but if i use Lambert , Blinn or other else , the UV Texture Editor will show the UV.
can anyone tell me what's happened ?
Thanks.
George Sears
Re: why does UV Texture Editor not show the image?
on Apr 8, 2015 at 5:58:16 pm
Hi HongWei Li,
If you haven't already found the solution:
If you click on the "Display image on/off" button in the UV Texture Editor, and nothing shows up, you can go to the Textures drop-down menu (in the UV Texture Editor) and select the texture map you want to show up (Diffuse, Spec, Bump, etc...) in the editor (this is usually sufficient.)
If that doesn't work, you can go to the Material Attributes (of the offending material,) and near the bottom, go to the Hardware Texturing tab, make sure "Texture channel" is set to "Diffuse" (sometimes it automatically switches to "None")
Once you make sure that that's set, your UV Texture Editor should show the proper image (instead of black.)
Hope that helped!
Kill me again; I dare you!
