NURBS to Poly artifacts
COW Forums : Autodesk Maya
Alex Vlair
on Jan 9, 2015 at 10:50:18 am
Hey all,
I'm hoping someone here has experience with converting NURBS surfaces to Poly surfaces and the artifacts that can arise. Here's a screencapture of what I'm dealing with:
The grey spots flash around when the arm moves (the arm is connected to joints and an IK).
I suspect this is a tesselation issue caused by the NURBS to Poly convert, but I'm not sure. If anyone has any insight into this issue, I'd greatly appreciate it! I already asked in another forum but didn't get any response.
Matt Nielsen
Re: NURBS to Poly artifacts
on Mar 23, 2015 at 3:50:41 am
Hi Alex
Without seeing the process it might be a little hard to determine but here are a few ideas.
  • First check your normals.. You may need to reset by applying a soften or harden. Additionally you may have some inverted normals (which shouldn't occur but I have seen it before)
  • Are you working with duplicate objects occupying the same space? When you copied did you hide or remove the object it was copied from?
  • How are you tesselating your geometry? What settings are you using? For something so smooth it still has a hexagonal profile.
  • Maybe throw a new material on the geometry and see if it is still occurring.
Hopefully one of these ideas works. Good luck
© 2018 All Rights Reserved
