Watching an .iff image sequence from your HDD?
COW Forums : Autodesk Maya
Max Nuage
on Dec 4, 2014 at 11:09:54 pm
Hello Cow community!
I've been working on an animated short that I've been preparing for the final render stage. Today I've exported an IFF sequence of a very long shot of over 1000 frames through Maya's playplast. While I was able to look at the sequence within the program after it was completed, I was unable to play the sequence from my HDD later on. Whenever I open one of the iff files, I'm only able to view the frame I've opened. Is there a way to view the whole sequence like in Maya's Playblast window?
Thanks in advance! :)
Eric Santiago
Re: Watching an .iff image sequence from your HDD?
on Dec 20, 2014 at 5:34:50 pm
Did you try using fcheck > animation?
You can find fcheck in the program folder.
