Render in VRAY ( Black character ) in MAYA 2015
COW Forums : Autodesk Maya
khaled yusef
on Nov 21, 2014 at 10:11:48 pm
Hey guys , im using the vray 2.40 , so i render in maya 2015 , and when im render it give me a good image but the character is totally BLACK . Any Help plzzzzzz
Kyran Bishop
Re: Render in VRAY ( Black character ) in MAYA 2015
on Dec 17, 2014 at 3:55:07 pm
Could be an issue with the normals? You can check them by going to the toolbar and finding 'Display > Polygons > Face Normals' - if the lines are pointing inside the model then your normals are wrong.
Or if it's not the normals, try applying a Vray Mtl to the model and re-rendering to see if its an issue with your currently existing material setup.
Or as a final thing it could be an issue with the light linker (although this is unlikely as your shadows appear to be functioning just fine) but the lights may not be applied to the model, just the background.
Hope that helps!
