Animating Paper Unfolding in Maya
COW Forums : Autodesk Maya
Jun-Lin Harries
on Nov 17, 2014 at 1:27:22 pm
Hi guys! For a project I'm currently working on in Maya, I need to animate paper unfolding and forming the environment.
For example:
But I'm not sure where to even start with it, so suggestions on how to approach it would be much appreciated! Thank you!
Amish Pathak
Re: Animating Paper Unfolding in Maya
on Dec 1, 2014 at 9:16:43 am
Hi Jun-Lin Harries,
This may not be the best idea out there but here's what you can try out.
Say you have a building modeled in maya.
Convert it to nCloth and simulate. (I guess basic settings will do)
Render out the frames as image files.
Reverse them in After Effects or something.
I guess this will be the quickest way to achieve this kind of effect.
One of the million ways to achieve this in maya. :)
Hope this helps.
Matt Nielsen
on Mar 23, 2015 at 3:05:15 am
I would think that you could create this effect quite easily using Blendshapes. There are a lot of resources on youtube and on the net.. Hope this helps
I should have also said that if you connect the blendshape to an object like a NURBS circle you will have exact control over how the object blends.
