S>O>S> I have a Maya glitch
COW Forums : Autodesk Maya
eddy schwartz
on Oct 29, 2014 at 9:09:17 pm
I have been using Maya Autodesk 2013 for months. I am no expert, but I have created a few models. All was happy and smooth when suddenly...
I am in Polygon modeling. I create a polygon cube. I right click on the cube to Vertices. I select one vertice on the corner (any corner). I use the manipulator to drag that one vertice and.....
...to my horror...
...the entire cube moves. The more I drag it, the more it turns into a 3d parallelogram.
What a drag. I have already gone to windows, and reset my preferences to default, but that didn't give e back control of my vertices.
Any help would be greatly appreciated. And thank you very much for your time.
Eddy in Prince Edward Island, Canada
eddy schwartz
Re: S>O>S> I have a Maya glitch
on Nov 4, 2014 at 11:06:02 pm
Did I hit a something on the keyboard by accident?
Any body our there?
Alvaro Castaneda
on Nov 4, 2014 at 11:25:02 pm
seems like you might have the proportional and/or mirror options activated, double click the move tool icon and press the Reset Tool button at the top in the options.
that might help.
varomix - pixelEater
MIX Studio
http://www.varomix.net
eddy schwartz
on Nov 5, 2014 at 1:27:21 am
Thank you, Alvero! I was about to do a follow up. Yes, you are so right. Here's what I did before I came back to Creative Cow:
Modification> Transformation Tools> Proportional Modifications Tools (check the box)> Distance Based On click off the X Y Z)
...which works, but on one object at a time... I will follow your lead, Alvaro, and thank you again for your response.
I will return with the results....
eddy schwartz
on Nov 5, 2014 at 1:52:16 am
Alvero, the move tool was already set at default. To be certain, I Dble clicked on it (and the rotation and size tool), hit the reset which didn't seem to change anything.
So far, all I can do is repeat the maneuver as mentioned above. At least I can continue working on my model.
If there are more suggestions or ideas, please let me know.
Thanks again.
Matt Nielsen
on Mar 23, 2015 at 3:59:43 am
When you select the component do the other components show up in a red and yellow shade? If so you may have accidentally enabled soft selection. Just press B again to disable the soft select.
To be honest it doesn't sound like this is the problem but you never know.
eddy schwartz
on Mar 23, 2015 at 8:48:40 pm
hey Matt...
I discovered a while back what had happened. It was the brush size. To solve the problem, I pressed 'b' and dragged until the radius went to zero. I am back to making antique cars along with all you good model makers out there.
Thanks for the help, every one.
Strath Hamilton
on Jun 16, 2015 at 5:56:11 pm
This helps so much
Strath Hamilton
TriCoast Studios
eddy schwartz
on Jun 16, 2015 at 11:37:09 pm
that's what I love about internet and its technology. It allows us, people from all over the world, to communicate and learn from one another.
