text animation
COW Forums : Autodesk Maya
Andrew Cain
text animation
on Oct 9, 2014 at 7:51:26 pm
Hello,
I have attached text to a circle, attach to motion path, then to flow path. I have adjusted the base, etc. and all looks perfect. But when I press play it just sits there not moving around circle. Its been a while since I've animated w/Maya and I'm sure this is a level 1 sort of problem and sure could use a push.
AC
