DX11 shader doesn't work!
COW Forums : Autodesk Maya
Mohannad Al-Khatib
on Oct 2, 2014 at 9:27:27 pm
I recently had to format my computer and when I reinstalled Maya and loded the DX11 shader, it doesn't work. Here is a screenshot
I've updated my drivers and made sure Maya is being rendered using the Nvidia GPU with the drivers being up to date.
Here are the Specs:
Maya 2015 SP4 64bit
Wintos 7 64bit
i7-4800MQ 2.70GHz
24GB Ram
Intel(R) HD Graphics 4600
Any advice?
Thank you!
Mohannad Al-Khatib
Re: DX11 shader doesn't work!
on Oct 3, 2014 at 5:42:21 pm
When I force Maya to run with the Intel Integrated GPU, the shader works, but not when running using the NVidia dedicated GPU. I also ran dxdiag to confirm I had DX11 installed. I even ran Geforce DX11 demos with no problems. So it has to be an issue with the way Maya tries to render with Nvidia's drivers. I tried installing older drivers, and installed all optional windows updates with no luck!
I'm out of options!
© 2018 All Rights Reserved
