Maya Data Loss Error
COW Forums : Autodesk Maya
Sam Pipes
on May 29, 2014 at 7:09:33 pm
Sorry to bother everyone with what may be a routine problem, but I've recently begun having problems with a file I'm working on. When I open it it takes forever, then I get the error warning of data loss. On the surface the only missing data is a few key frames, though I fear there are hidden problems I haven't seen.
Loading GoZ support...done!
file -f -new;
// Warning: file: C:/Program Files/Autodesk/Maya2015/scripts/startup/rememberViewportSettings.mel line 43: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
animCurveEditor -edit -stackedCurvesMin -1 -stackedCurvesMax 1 -stackedCurvesSpace 0.2 -stackedCurves true graphEditor1GraphEd;
// graphEditor1GraphEd //
// untitled //
commandPort -securityWarning -name commandportDefault;
// AbcExport v1.0 using Alembic 1.5.0 (built Jul 25 2013 11:21:20)
// AbcImport v1.0 using Alembic 1.5.0 (built Jul 25 2013 11:21:20)
updateRendererUI;
file -f -options "v=0;" -typ "mayaBinary" -o "D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/Clumsy_Smurf_Posesv2.mb";addRecentFile("D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/Clumsy_Smurf_Posesv2.mb", "mayaBinary");
Time: 2014/5/29 15:26:23
requires -nodeType "mentalrayFramebuffer" -nodeType "mentalrayOptions" -nodeType "mentalrayGlobals" -nodeType "mentalrayItemsList" -nodeType "mib_amb_occlusion" -nodeType "misss_call_shader" -nodeType "mi_car_paint_phen_x_passes" -dataType "byteArray" "Mayatomr" "2015.0 - 3.12.1.12 ";
# mental ray for Maya 2015
// Mental ray for Maya: using startup file C:/Program Files/Autodesk/mentalrayForMaya2015//maya.rayrc.
# mental ray for Maya: setup
# mental ray for Maya: initialize
# mental ray for Maya: register extensions
// mental ray Node Factory: loaded
# mental ray for Maya: successfully registered
# mental ray for Maya: loading startup file: C:/Program Files/Autodesk/mentalrayForMaya2015//maya.rayrc
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/abcimport.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/abcimport.dll
// generating Maya nodes...
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/AdskShaderSDKWrappers.mi
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/architectural.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/architectural.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/base.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/base.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/basehair.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/basehair.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/bifrostMR.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/bifrostMR.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/bifrostphenMR.mi
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/builtin_bsdf.mi
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/contour.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/contour.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/layering.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/layering.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/layering_phen.mi
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/mrptex.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/mrptex.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/paint.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/paint.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/physics.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/physics.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/production.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/production.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/subsurface.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/subsurface.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/surfaceSampler.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/surfaceSampler.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/userdata.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/userdata.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/useribl.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/useribl.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/include/xgenMR.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2015/shaders/xgenMR.dll
requires -nodeType "cMuscleShader" "MayaMuscle" "2.00 (Build: 004)";
requires -nodeType "decomposeMatrix" "matrixNodes" "1.0";
requires "spConnectionExist" "7.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "spConnectionExist", was not found on MAYA_PLUG_IN_PATH. #
requires "spCmptAsmbNd" "1.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "spCmptAsmbNd", was not found on MAYA_PLUG_IN_PATH. #
requires "rotoNode" "4.5";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "rotoNode", was not found on MAYA_PLUG_IN_PATH. #
requires "depthOfFieldView" "1.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "depthOfFieldView", was not found on MAYA_PLUG_IN_PATH. #
requires "ABCamera" "8.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "ABCamera", was not found on MAYA_PLUG_IN_PATH. #
// Warning: line 0: Unrecognized node type for node 'clumsy'; preserving node information during this session. //
// Warning: line 0: Unrecognized node type for node 'clumsy_hat_basic'; preserving node information during this session. //
// Warning: line 0: Unrecognized node type for node 'clumsy_pants_basic'; preserving node information during this session. //
// Warning: line 0: Unrecognized node type for node 'clumsy_face_exists'; preserving node information during this session. //
dataStructure -fmt "raw" -as "name=externalContentTable:string=node:string=key:string=upath:uint32=upathcrc:string=rpath:string=roles";
// externalContentTable //
applyMetadata -fmt "raw" -v "channel\nname externalContentTable\nstream\nname v1.0\nindexType numeric\nstructure externalContentTable\n0\n\"|pointLight1|pointLightShape1\" \"dmapName\" \"depthmap\" 2097411553 \"\" \"sourceImages\"\n1\n\"|pointLight2|pointLightShape2\" \"dmapName\" \"depthmap\" 2097411553 \"\" \"sourceImages\"\n2\n\"|pointLight3|pointLightShape3\" \"dmapName\" \"depthmap\" 2097411553 \"\" \"sourceImages\"\n3\n\"|spotLight1|spotLightShape1\" \"dmapName\" \"depthmap\" 2097411553 \"\" \"sourceImages\"\n4\n\"clumsy_hi_lf_eyeball_inner_color_shader_ramp_pupil_file\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" 1932040841 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" \"sourceImages\"\n5\n\"clumsy_hi_lf_eyeball_inner_color_shader_ramp_iris_file\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" 1932040841 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" \"sourceImages\"\n6\n\"clumsy_hi_lf_eyeball_inner_color_shader_ramp_sclera_file\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" 1932040841 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" \"sourceImages\"\n7\n\"clumsy_hi_rt_eyeball_inner_color_shader_ramp_pupil_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/pupilcolor/highest/512sq_dt8_tif/clumsy_hi_rt_eyeball_inner_tg.tif\" 1118429100 \"\" \"sourceImages\"\n8\n\"clumsy_hi_rt_eyeball_inner_color_shader_ramp_iris_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/iriscolor/highest/512sq_dt8_tif/clumsy_hi_rt_eyeball_inner_tg.tif\" 942035464 \"\" \"sourceImages\"\n9\n\"clumsy_hi_rt_eyeball_inner_color_shader_ramp_sclera_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/scleracolor/highest/512sq_dt8_tif/clumsy_hi_rt_eyeball_inner_tg.tif\" 1418066356 \"\" \"sourceImages\"\n10\n\"clumsy_hi_rt_teeth_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_R_teeth.jpg\" 1926993039 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_R_teeth.jpg\" \"sourceImages\"\n11\n\"clumsy_hi_lf_teeth_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_R_teeth.jpg\" 1926993039 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_R_teeth.jpg\" \"sourceImages\"\n12\n\"clumsy_hi_cn_butt_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_torso.jpg\" 1085342308 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_torso.jpg\" \"sourceImages\"\n13\n\"clumsy_hi_cn_ears_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_ears.jpg\" 3867696411 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_ears.jpg\" \"sourceImages\"\n14\n\"clumsy_hi_cn_face_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_face.jpg\" 1328409060 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_face.jpg\" \"sourceImages\"\n15\n\"clumsy_hi_cn_gums_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_gums.jpg\" 3317453557 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_gums.jpg\" \"sourceImages\"\n16\n\"clumsy_hi_cn_head_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_head.jpg\" 3728758654 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_head.jpg\" \"sourceImages\"\n17\n\"clumsy_hi_cn_tongue_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_tongue.jpg\" 2128918131 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_tongue.jpg\" \"sourceImages\"\n18\n\"clumsy_hi_cn_torso_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_torso.jpg\" 1085342308 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_torso.jpg\" \"sourceImages\"\n19\n\"clumsy_hi_lf_hand_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_L_hand.jpg\" 3314610443 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_L_hand.jpg\" \"sourceImages\"\n20\n\"clumsy_hi_lf_leg_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_head.jpg\" 3728758654 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_head.jpg\" \"sourceImages\"\n21\n\"clumsy_hi_rt_hand_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_R_hand.jpg\" 4244062288 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_R_hand.jpg\" \"sourceImages\"\n22\n\"clumsy_hi_rt_leg_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_pants_color_leg.jpg\" 2409213434 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_pants_color_leg.jpg\" \"sourceImages\"\n23\n\"clumsy_hi_cn_brows_tg_shader_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_cornea_tg.tif\" 1830368762 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_cornea_tg.tif\" \"sourceImages\"\n24\n\"clumsy_hi_lf_eyeball_inner_face_color_shader_ramp_pupil_file\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" 1932040841 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" \"sourceImages\"\n25\n\"clumsy_hi_lf_eyeball_inner_face_color_shader_ramp_iris_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/iriscolor/highest/512sq_dt8_tif/clumsy_hi_lf_eyeball_inner_tg.tif\" 1400923865 \"\" \"sourceImages\"\n26\n\"clumsy_hi_lf_eyeball_inner_face_color_shader_ramp_sclera_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/scleracolor/highest/512sq_dt8_tif/clumsy_hi_lf_eyeball_inner_tg.tif\" 1059310949 \"\" \"sourceImages\"\n27\n\"clumsy_hi_rt_eyeball_inner_face_color_shader_ramp_pupil_file\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" 1932040841 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" \"sourceImages\"\n28\n\"clumsy_hi_rt_eyeball_inner_face_color_shader_ramp_iris_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/iriscolor/highest/512sq_dt8_tif/clumsy_hi_rt_eyeball_inner_tg.tif\" 942035464 \"\" \"sourceImages\"\n29\n\"clumsy_hi_rt_eyeball_inner_face_color_shader_ramp_sclera_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/scleracolor/highest/512sq_dt8_tif/clumsy_hi_rt_eyeball_inner_tg.tif\" 1418066356 \"\" \"sourceImages\"\n30\n\"clumsy_hi_rt_teeth_tg_shader_face_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_R_teeth.jpg\" 1926993039 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_R_teeth.jpg\" \"sourceImages\"\n31\n\"clumsy_hi_lf_teeth_tg_shader_face_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_L_teeth.jpg\" 2388360002 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_L_teeth.jpg\" \"sourceImages\"\n32\n\"clumsy_hi_cn_ears_tg_shader_face_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_ears.jpg\" 3867696411 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_ears.jpg\" \"sourceImages\"\n33\n\"clumsy_hi_cn_face_tg_shader_face_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_face.jpg\" 1328409060 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_face.jpg\" \"sourceImages\"\n34\n\"clumsy_hi_cn_gums_tg_shader_face_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_gums.jpg\" 3317453557 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_gums.jpg\" \"sourceImages\"\n35\n\"clumsy_hi_cn_head_tg_shader_face_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_face.jpg\" 1328409060 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_face.jpg\" \"sourceImages\"\n36\n\"clumsy_hi_cn_tongue_tg_shader_face_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_tongue.jpg\" 2128918131 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_tongue.jpg\" \"sourceImages\"\n37\n\"clumsy_hi_cn_brows_tg_shader_face_clr\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_cornea_tg.tif\" 1830368762 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_cornea_tg.tif\" \"sourceImages\"\n38\n\"clumsy_hi_cn_ears_tg_shader_face_clr_b\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_ears.jpg\" 3867696411 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_ears.jpg\" \"sourceImages\"\n39\n\"clumsy_hi_cn_face_tg_shader_face_clr_b\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_face.jpg\" 1328409060 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_face.jpg\" \"sourceImages\"\n40\n\"clumsy_hi_cn_gums_tg_shader_face_clr_b\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_gums.jpg\" 3317453557 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_gums.jpg\" \"sourceImages\"\n41\n\"clumsy_hi_cn_head_tg_shader_face_clr_b\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_face.jpg\" 1328409060 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_face.jpg\" \"sourceImages\"\n42\n\"clumsy_hi_cn_tongue_tg_shader_face_clr_b\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_tongue.jpg\" 2128918131 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_body_color_B_tongue.jpg\" \"sourceImages\"\n43\n\"file2\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/eye_v03_00000.jpg\" 414199944 \"\" \"sourceImages\"\n44\n\"file3\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/eye_v03_00000_1.jpg\" 3288624849 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/eye_v03_00000_1.jpg\" \"sourceImages\"\n45\n\"Booya:clumsy_hi_lf_eyeball_inner_color_shader_ramp_pupil_file\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" 1932040841 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" \"sourceImages\"\n46\n\"Booya:clumsy_hi_lf_eyeball_inner_color_shader_ramp_iris_file\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" 1932040841 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" \"sourceImages\"\n47\n\"Booya:clumsy_hi_lf_eyeball_inner_color_shader_ramp_sclera_file\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" 1932040841 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" \"sourceImages\"\n48\n\"Booya:clumsy_hi_rt_eyeball_inner_color_shader_ramp_pupil_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/pupilcolor/highest/512sq_dt8_tif/clumsy_hi_rt_eyeball_inner_tg.tif\" 1118429100 \"\" \"sourceImages\"\n49\n\"Booya:clumsy_hi_rt_eyeball_inner_color_shader_ramp_iris_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/iriscolor/highest/512sq_dt8_tif/clumsy_hi_rt_eyeball_inner_tg.tif\" 942035464 \"\" \"sourceImages\"\n50\n\"Booya:clumsy_hi_rt_eyeball_inner_color_shader_ramp_sclera_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/scleracolor/highest/512sq_dt8_tif/clumsy_hi_rt_eyeball_inner_tg.tif\" 1418066356 \"\" \"sourceImages\"\n51\n\"Booya:clumsy_hi_lf_eyeball_inner_face_color_shader_ramp_pupil_file\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" 1932040841 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" \"sourceImages\"\n52\n\"Booya:clumsy_hi_lf_eyeball_inner_face_color_shader_ramp_iris_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/iriscolor/highest/512sq_dt8_tif/clumsy_hi_lf_eyeball_inner_tg.tif\" 1400923865 \"\" \"sourceImages\"\n53\n\"Booya:clumsy_hi_lf_eyeball_inner_face_color_shader_ramp_sclera_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/scleracolor/highest/512sq_dt8_tif/clumsy_hi_lf_eyeball_inner_tg.tif\" 1059310949 \"\" \"sourceImages\"\n54\n\"Booya:clumsy_hi_rt_eyeball_inner_face_color_shader_ramp_pupil_file\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" 1932040841 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/papa_hi_lf_eyeball_inner_tg.tif\" \"sourceImages\"\n55\n\"Booya:clumsy_hi_rt_eyeball_inner_face_color_shader_ramp_iris_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/iriscolor/highest/512sq_dt8_tif/clumsy_hi_rt_eyeball_inner_tg.tif\" 942035464 \"\" \"sourceImages\"\n56\n\"Booya:clumsy_hi_rt_eyeball_inner_face_color_shader_ramp_sclera_file\" \"fileTextureName\" \"/shots/smf/char.clumsy.tex/pix/ptex/clumsy_hi/scleracolor/highest/512sq_dt8_tif/clumsy_hi_rt_eyeball_inner_tg.tif\" 1418066356 \"\" \"sourceImages\"\n57\n\"file4\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_pants_color_sole.jpg\" 410522065 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_pants_color_sole.jpg\" \"sourceImages\"\n58\n\"file5\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_pants_color_leg.jpg\" 2409213434 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_pants_color_leg.jpg\" \"sourceImages\"\n59\n\"file6\" \"fileTextureName\" \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_pants_color_shoe.jpg\" 1531665905 \"D:/Google Drive/Project Files/Smurfs/Original iTalk Assets/Clumsy Smurf/ClumsyTex/clumsy_pants_color_shoe.jpg\" \"sourceImages\"\nendStream\nendChannel\nendAssociations\n" -scn;
// 1 //
// Error: line 1720: scriptedPanel: Object 'Stereo' not found. //
// Warning: line 0: Errors have occurred while reading this scene that may result in data loss.
Please check the Script Editor for details. //
// File read in 17.9 seconds.
// Warning: file: C:/Program Files/Autodesk/Maya2015/scripts/others/hyperShadePanel.mel line 6868: The currently active tab is not a scene tab. This icon size change operation is not implemented for this tab. //
setAttr AO1.precompTemplate -type "string" "";
setAttr Lighting.precompTemplate -type "string" "";
updateRendererUI;
I get the same problem on every incarnation of the file. I think it may have something to do with upgrading from Maya 2014 to 2015.
I'm quite new to Maya, and unsure how to parse the error messages. Any help would be appreciated.
