Image Size Doesn't Match My Rendered Size
COW Forums : Autodesk Maya
Lillian Young
on May 11, 2014 at 3:01:17 pm
My render is set to HD 720, Size Units Pixels, Res 72, Device AR 1.77 and Pixel AR 1, Maintain ratio is on. Yet when I render, I get 960x540. For 1920x1080 it's rendering 1440x810.
This is odd because I just batch rendered 1920x1080 successfully overnight. I don't know what happened to mess up my settings but I am frustrated.
Update: The problem still exist but I've realized that for batch renders, it renders as specified (correctly). However for stills, no matter what format I select (tif, psd, jpg) the above issue persists.
Any guidance is appreciated.
Using: Maya 2014, Mac OS X (10.8.5)
Lillian Young
Re: Image Size Doesn't Match My Rendered Size
on May 11, 2014 at 7:15:32 pm
I found a solution although I am still confused because I've never had to do these steps before:
"I would also check the film aspect ratio in your camera and make sure it matches your device aspect ratio in your render settings." - BurningFencePost
Source: http://forums.cgsociety.org/archive/index.php/t-413352.html
Leon Duffy
on May 30, 2014 at 4:24:37 pm
your using a 'test resolution' which is a percentage of your current render resoloution
Make sure your in the Render menu set then under file menu choose Render>Test Resolution
You've probably worked it out by now but hope this helps.
Lillian Young
on Jun 8, 2014 at 12:17:02 am
Perfect, Leon. I've never heard of that before. Solved. Thank you!
