Transferring Texture Attributes
COW Forums : Autodesk Maya
Sam Pipes
on Apr 25, 2014 at 5:43:08 pm
I'm working on a project where I've been given a pre-made character to animate. I'm almost entirely new to Maya, though I have a lot of experience in Max.
When I got the character, he had a bunch of different material attributes on him, each for a different portion of the mesh. At some point I accidentally overwrote these, applying one material to the entire model. So now I need to go into a previous version of the file, grab the textures (or the attributes, I guess?) And apply them to the new version. I have no idea how to do this. Any tips for a newbie?
Geoffrey Kfoury
Re: Transferring Texture Attributes
on Apr 26, 2014 at 5:14:27 pm
Hi Sam,
If I understand your issue correctly, the materials have not been overwritten at all! To me, it sounds like you have assigned a default or pre-existing material to your entire model. The materials that were previously applied to your model should be located in the Hypershade window.
Windows > Rendering Editors > Hypershade
Hope this helps.
© 2018 All Rights Reserved
