Trying to deactivate an animation clip in Trax Editor via Mel
COW Forums : Autodesk Maya
Alex Jørgensen
on Mar 21, 2014 at 11:56:04 pm
Hi guys,
I feel like I've searched the web for everything it's got but I'm fairly new to Mel so I hope this is not a stupid question.
I'm trying to make an automated-export script and in doing so I need to Activate and deactivate an animation clip in the trax editor. Funny thing is I can activate it no problem the following does the trick:
clip -edit -active $animName $characterSet;
But when I try to deactivate nothing seems to work, what I don't get is why this won't work;
clip -edit -active off $animName $characterSet;
I get this error message: / Error: line 3: Must select a single character or a clip library. //
And I have no clue what to do about it. As far as I understand it, it's asking for a character which (if I'm not mistaking) is exactly what I'm giving it as the last input.
Standard google searches didn't really provide any results, so now I come to you guys hoping someone have experience with this! :)
Any help would be much appreciated!
- Alex
Alex Jørgensen
Re: Trying to deactivate an animation clip in Trax Editor via Mel
on Mar 22, 2014 at 9:46:12 am
Alright nevermind, a couple of hours of sleep apparently did the trick.
For anyone in the same problem here's how I solved it.
The -active flag does not take a bool but a string so the command ends up looking like this
clip -edit -active "default" -name $animName -character $char;
Steve Sayer
on Mar 24, 2014 at 2:34:41 pm
Thanks for posting the solution!
