Trouble Modeling An Arched Doorway
COW Forums : Autodesk Maya
Lillian Young
on Feb 20, 2014 at 3:34:07 am
I am trying to model a door that recesses into the wall with hard side corners and a smooth, shallow arch (as pictured).
I thought this would be very easy, and have modeled other geometry in the scene (seemingly complicated) in a fraction of the time, but have found myself struggling with this door.
What I have now is a sloppy workaround (multiple edge loops for shaping), a poorly executed extrude with bad edge flow.
The Doorway (my failed attempt)
The Doorway (actual photo)
Eric Santiago
Re: Trouble Modeling An Arched Doorway
on Mar 3, 2014 at 8:00:01 pm
Does it have to be one geo?
I would have cut a hole using Boolean then create the archway separate.
You can build that the same as in real life too.
