Maya crashes while switching viewports and with a white flash
COW Forums : Autodesk Maya
Roshan Josh
on Feb 6, 2014 at 12:08:10 pm
my pc is -
I7 3770k
8 gb ram
Zotac gtx 650 Ti AMP Edition 2GB
I am using Maya 2014 64-bit. It ran smoothly for 1 month then suddenly there were these white flashes while changing viewports and then Maya will crash. I have tried everything.My graphic drivers and other drivers are all up to date.I have even formatted my window but still the problem remains. However the problem gets solved by disabling aero theme , but i want to know any method other then that cause changing tabs while working in basic theme is tough and irritating. Some people said that it has something to do with .net framework. I want to know the answer cause no forum has the correct answer or explanation to this and this problem exists at a large amount. If possible can someone make a patch or write a script for it.
That would be great help !!!!
(If possible please reply)
James Peres
Re: Maya crashes while switching viewports and with a white flash
on Feb 15, 2014 at 11:23:29 pm
Have you deleted your prefs? Try trashing your userPrefs.mel file.
James
Mac Pro 4,1 Quad Core 2.66
