intensity of the light based on its distance from mesh
COW Forums : Autodesk Maya
Jovan Strel
on Feb 1, 2014 at 10:14:09 pm
hi,
i need help with controlling the intensity of the light based on its distance from points of the mesh
what i need is a way to tell a light to look for the closest point on the mesh and depending from the distance, intensity of the light is controlled.
does anyone have a suggestion? much much thanks
i have done some test, but the only i could get to work is calculating the distance between two objects, but what i need the distance between closest point on mesh and light
any help, tip, you would be a lifesaver
Steve Sayer
Re: intensity of the light based on its distance from mesh
on Feb 5, 2014 at 5:00:34 pm
There is a 'closestPointOnMesh' node that should be exactly what you need.
http://download.autodesk.com/global/docs/maya2014/en_us/Nodes/closestPointO...
