Modelling this component
COW Forums : Autodesk Maya
Andrew Clancy
on Jan 15, 2014 at 6:38:08 am
Hi All
I am trying to model the an ACFM Probe that is used for weld inspection , typically subsea by commercial divers. Any advice on how to create the probe tip?
Otto Lindqvist
Re: Modelling this component
on Jan 20, 2014 at 9:03:33 am
I'd maybe start with a polyCylinder and polyCube, set them into correct positions (distance between faces is 7 units) and then set the number of sides equal and bridge them together. Before bridging I'd model the round parts of the cube to match the cylinder so the shape is perfect. Then add edgeloops and smooth.
I think maybe 12 sides for the cylinder would do the trick.
I currently have no Maya with me so I cant test this out, but I think this would work. Let me know if you need more clarification to this.
I hope this helps.
If it's not moving, animate it
James Peres
on Feb 16, 2014 at 12:56:34 am
Yea, just get a cylinder and extrude it, then shrink the extrusion. I would actually have the cylinder with no caps, so that I can control how I want to polys to wrap around later on.
Mac Pro 4,1 Quad Core 2.66
© 2018 All Rights Reserved
