maya dynamics (expressions)
COW Forums : Autodesk Maya
Ryan Watson
on Dec 11, 2013 at 2:50:39 am
I'm a beginners learning Maya dynamics and I an having a problem with my expressions
This is the expression --> particleShape1.radiusPP=rand(1,2)
// Error: Attribute not found or variable missing '$': particleShape1.radiusPP //
Thanks for your help
Regards
Steve Sayer
Re: maya dynamics (expressions)
on Dec 30, 2013 at 3:14:55 pm
Particle objects don't have the radiusPP attribute by default; you have to add it manually.
There should be an 'Add Dynamic Attributes' section in the particle shape node's Attribute Editor. Click on the 'General' button (other options are 'Opacity' and 'Color'). That will open a window with a menu allowing you to add various per-particle attributes, including radiusPP.
Ryan Watson
on Jun 20, 2014 at 4:51:56 pm
Steve,
My apologies for the long delayed response. Thank you for your expertise, it work as you probably knew. Thanks again kind sir!
Regards
Ryan
