problem adding mateials to .obj files maya 2014
COW Forums : Autodesk Maya
King Law
on Nov 24, 2013 at 1:10:54 am
I created some txt with Mograph in c4d 2013 converted the Mograph to mesh then export the file as .OBJ. only problem is when i import the file into Maya 2014 and try to add a material(BLIN) the color shows in the view port but when i render with mental ray the letters still look grey(the default LAMBERT) can anybody help how to solve this issue? Please!!!
Adam Kaczmarek
Re: problem adding mateials to .obj files maya 2014
on Jan 7, 2014 at 4:58:44 pm
Did you change color of your blinn in Maya or you left it as default (grey)? Are there any other objects in your scene (mesh, lights)? What renderer do you use (mental ray/maya software)?
