Error/bug "has no shading group associated with it."
COW Forums : Autodesk Maya
Syrol Trent
on Oct 12, 2013 at 8:17:30 pm
I've been looking for a solution to this, but haven't found any threads that help me fix this.
I've got a mesh I'm working on that shows up fine on the screen, but when I go to render, nothing is visible. When I run render diagnostics, I get this:
"Starting diagnostics...
Known Problems/Limitations
Warnings
- polySurfaceShape1 has no shading group associated with it. This
means that it will not be rendered. Please assign it to a shading group.
Speed/Memory Implications
- it can be useful to run your scene through "maya -optimizeRender"
before rendering. This can help optimize the scene for rendering.
Diagnostic Completed..."
I've tried replacing the object material, but that doesn't help. Oddly, when I make a subD proxy, the proxy shows just fine in the render window, but the source geometry doesn't.
HELP!
