Camera is Warping Spheres (Oblong Shape)
COW Forums : Autodesk Maya
Lillian Young
on Sep 4, 2013 at 2:59:29 pm
I have a simple scene with spheres lined up side by side, but the camera is warping the ones on the outter sides.
They look a little oblong, and I am guessing it's a camera setting issue because when zoomed out, they're fine. But I don't know what to change the camera to.
Any ideas? - Thanks!
Stuart Christensen
Re: Camera is Warping Spheres (Oblong Shape)
on Sep 4, 2013 at 9:46:18 pm
Hello Lillian...Did you try creating some new cameras to see if they react the same in the scene? I made some spheres the way you have described and by default everything looks as it should....did you make any type of adjustments to your camera (is it the default perepective camera?).....A pic might also help posssible. Need more info...OK?
Stu
Eric Santiago
on Oct 2, 2013 at 1:28:10 pm
Its obvious you moved your cameras focal and position causing lens distortion.
You can delete that camera and create a new one.
The default will be a clean set.
