Maya crashes when i render
COW Forums : Autodesk Maya
Mattias Pedersen
on Aug 29, 2013 at 1:33:44 pm
Hi everyone,
I have bounced into a major problem. Every time I try to render my scene Maya crashes at 98% leaving me this message.
// Error: file: /Applications/Autodesk/maya2013/Maya.app/Contents/script/startup/updatePanelLayoutFromCurrent.mel line 58: Cannot find procedure “findStartUpCamera”.
I’m rendering with Vray. 2.0
I honestly have no clue how to deal with this problem. Please help.
Mattias Pedersen
Re: Maya crashes when i render
on Aug 29, 2013 at 6:41:05 pm
do someone know the problem?
Steve Sayer
on Sep 30, 2013 at 2:13:27 pm
Sorry for the late reply, Mattias.
Unfortunately I don't know for sure what the problem is.
Running the command 'whatIs findStartUpCamera' in Maya reveals the following:
// Result: Mel procedure found in: [path]/maya/2012-sp1/scripts/startup/findStartUpCamera.mel
The [path] part is specific to my system here; it will be different for you. But anyway, it looks like that file is damaged or missing for you. Navigate to your scripts/startup folder and see what you can see. If the file is missing, you could search your computer for it and try to replace it... if it's there, it might be corrupt, I guess? In either case, a reinstall of Maya might be your best bet.
All of this is just a wild guess, really... not sure if the problem is actually somewhere else. But it's what I'd start with.
Good luck.
