Vray IM/GI problem
COW Forums : Autodesk Maya
Aaron Pozzer
Vray IM/GI problem
on Jul 3, 2013 at 5:17:52 pm
Im having a problem with the GI render element turning black when doing Vray animation renders. I followed these instructions...
... which are for rendering animations, but then the GI pass disappears (turns black). It works fine with the IM and LC set to single frame though. Seems silly that if this data is pre-calculated its not passed on to the render element, which seems to be the case, unless im simply missing a check box or something.
Just wondering if anyone else has experienced this. For now I can render with single frame settings, but it would be nice to get it working as the link describes. Im sure some render time savings would be had.
© 2018 All Rights Reserved
