Importing an object with ncloth into nuke
COW Forums : Autodesk Maya
Fayzal Badat
on May 28, 2013 at 11:48:45 pm
hi there, i've got a table with a basic ncloth simulation i was just wandering what would be the best way to export it into nuke, seeing how it has ncloth that means it has animation frames but nuke accepts .obj and im not sure if thats just the object and not the animation, would be helpful if you could clear this up for me.
Ben van Hamelen
Re: Importing an object with ncloth into nuke
on Jun 1, 2013 at 4:41:46 pm
There is a way to bake your dynamics animations into an .obj sequence. I've done it before, but I'm not entirely sure how I did it. Probably with a Geometry Cache.
I'd google on exporting animation with a geometry cache and see where it gets you. An .obj sequence is the way to go though, that much I can tell you.
http://www.fireinthesole.com/
