imported track from matchmover 2013 to maya 2013, image plane issues
COW Forums : Autodesk Maya
Fayzal Badat
on May 28, 2013 at 10:39:26 pm
Hey there, like the title says, I've imported my track from matchmover to maya, the tracks are all there, only issue is when I looked through the tracked camera, the image sequence doesn't play and it only comes out during renders. I have provided two images below to show what's happening. thanks
Ben van Hamelen
Re: imported track from matchmover 2013 to maya 2013, image plane issues
on Jun 1, 2013 at 4:36:27 pm
I'm going out on a limb and say the image sequence you're using has an underscore or a different 'special' character in it. Maya doesn't like that. I've found that replacing the underscores by dots should work. So instead of 'Image_Sequence_0001.jpg', go for 'Image.Sequence.0001.jpg'.
http://www.fireinthesole.com/
