Manipulating Extruded Face Affects Entire Object
COW Forums : Autodesk Maya
Cameron Dozier
on May 4, 2013 at 9:07:23 pm
When I select a new face that I have extruded, it highlights the surrounding edges in red (the red highlight fades to a yellow, almost like the face affects the object only to a certain distance) and when I manipulate the newly extruded face's size, it affects the entire shape accordingly, like the face is pulling on the entire object when I change it's size. I've seen tons of tutorials where guys are extruding faces and changing their size and it just affects the face itself, and the edges DIRECTLY connected to that face, as apposed to the entire object bending to the shape of the extruded face. What do I have turned on that is causing this? Please help, thanks.
Cameron Dozier
Re: Manipulating Extruded Face Affects Entire Object
on May 4, 2013 at 9:16:03 pm
Nevermind, I figured it out, I had the SOFT SELECTION turned on, and just had to press the B key to turn it off. THANKS!
