Render Wireframe & Vertices
COW Forums : Autodesk Maya
Justin Sims
on Apr 26, 2013 at 6:57:39 pm
I know there are a lot of post about rendering wireframes, which I have been successful at in the past. I'm trying to render our a wireframe with the vertices. I just want a little more control over seeing the actual lines and the points that make up the lines than I have seen from other tutorials on rendering wireframes.
Steve Sayer
Re: Render Wireframe & Vertices
on Apr 29, 2013 at 3:28:35 pm
Hi, Justin. It's a bit difficult to answer this without knowing what renderer you're using.
In general, if you want to make verts visible, a possible solution is to turn the object into a softbody. That will create a particle at each vertex, which you can then render using your method of choice.
Justin Sims
on Apr 29, 2013 at 5:16:03 pm
Essentially I am trying to recreate a form like this this. I know I could do it in illustrator or photoshop, but I was looking for something slightly easier that would also give it more of an organic look.
Stuart Christensen
on May 1, 2013 at 7:32:48 pm
Hey Justin, check out this tutorial by Escapeephil...I would imagine that if you had your verts on it would work just the same.
Hope that helps!
