Vray environment is not showing in viewport
COW Forums : Autodesk Maya
Otto Lindqvist
on Mar 18, 2013 at 6:04:33 pm
I'm wondering if here's any VRay users? I'd like to ask a solution for my problem that when I apply HDR environment for background texture, why it is not showing in viewport? It should be visible, but I dont know why it's not.
I also tried to use dome light to create image based lighting but there was the same problem that I couldnt see how is the texture placed even if I checked enable from viewport display tab in dome light settings. Is there any way how could I see the environment so that I could place the map correctly?
If it's not moving, animate it
