What's the best model format I can export from 3ds Max to Maya?
COW Forums : Autodesk Maya
Lee Wit
on Jan 27, 2013 at 11:45:46 am
Hi experts,
I want to render a still shot for a press advertisement in Maya.
I found out that most of the free models online are for 3ds Max. So I decided to download quite a few, export them from 3ds Max and import them into Maya.
I need to know what's the best format to which I can export the models from 3ds Max so Maya can open them with as less damage as possible and as more editability as possible.
Also I would appreciate any feed on how much possible it is to apply different materials to geometries imported from 3ds Max.
I know I could try it all by myself but thought I would most probably miss important things only Maya experts can spot.
If there is no real solution, I would have to redesign Maya basic structure in 3ds Max and continue from there. But as I'm learning Maya I prefer otherwise.
Hope you can help.
Lee
Ben van Hamelen
Re: What's the best model format I can export from 3ds Max to Maya?
on Jan 28, 2013 at 8:25:31 am
Hi Lee,
Go with FBX. If I remember correctly, Autodesk owns that format. So it should translate to Maya pretty well. If not, go for OBJ.
I'm not sure what you mean by this, so I can't quite help you with that one: "Also I would appreciate any feed on how much possible it is to apply different materials to geometries imported from 3ds Max."
Cheers,
Ben van H.
http://www.fireinthesole.com/
Lee Wit
on Jan 29, 2013 at 9:23:01 pm
Thank you Ben.
Yes it does work the way you said. And I realized that 3ds Max simply "sends" the scene to Maya! I have done that and got all my design in Maya.
After I finished I had another problem with rendering. I will post a question about it. Hope to see you there :)
Thanks again,
Lee
James Trent
on Feb 3, 2013 at 2:55:19 am
Generally exporting as a FBX should carry just about everything nicely over to Maya, it has been awhile since I used 3ds max but it might use a different default coordinate system and/or scale system, in that case after you import into Maya simply scale and rotate it to correct direction, and it should be just fine.
