Linking slider to variable
COW Forums : Autodesk Maya
Otto Lindqvist
on Jan 23, 2013 at 8:08:51 am
There's another problem from me. For some reason I cant get this getting value from slider thing working...
What I'm doing wrong? It's giving me syntax error from the last 2 procedures.
//Create window
window -title "Create new grill" -rtf true GrillMakerWindow;
columnLayout;
intSliderGrp -label "Width" -field true
-value 0 -minValue 0 -fieldMinValue 0 -cc getWidthSlider
-dc getWidthSlider Width;
intSliderGrp -label "Height" -field true
-value 0 -minValue 0 -fieldMinValue 0 -cc getHeightSlider
-dc getHeightSlider Height;
intSliderGrp -label "Grillholes width" -field true
-value 0 -minValue 0 -fieldMinValue 0 GrillWidth;
intSliderGrp -label "Grillholes height" -field true
-value 0 -minValue 0 -fieldMinValue 0 GrillHeight;
intSliderGrp -label "Edge width" -field true
-value 0 -minValue 0 -fieldMinValue 0 EdgeWidth;
button -label "Create Grill" -command "GrillMaker";
showWindow GrillMakerWindow;
proc getWidthSlider()
int $width = 'intSliderGrp -v Width';
print $width;
proc getHeightSlider()
int $height = 'intSliderGrp -v Height';
print $height;
Thanks for helping me
If it's not moving, animate it
Steve Sayer
Re: Linking slider to variable
on Mar 4, 2013 at 3:16:16 pm
Hi, Otto.
I think you're using the wrong quotes there.
You need the single forward quotes that you can find above the Tab key on your keyboard, next to the 1 key... not the single generic quotes next to the Enter key.
