How to control insert edge loop and offset edge tool in mel?
COW Forums : Autodesk Maya
Otto Lindqvist
on Jan 23, 2013 at 5:09:51 am
Hello,
I'm writing a script to create grills. However I couldnt figure out how to use offset edge tool and insert edge tools my mel. Is here anyone who know how to control those?
I tried using extrude, but the topology I'll get with extruding is different than I need.
Is there also possible to use generally keep faces together command by mel? If I use it in polyExtrudeFacet there's something wrong in the geometry.
Otto
If it's not moving, animate it
