How can i get this Light bulb effect (check the image attached)
COW Forums : Autodesk Maya
King Law
on Jan 14, 2013 at 3:40:59 am
i have modelled a light bulb with clear glass and i want to light up the filament(the springy wire inside the bulb). Now i know how to emit light from an object but i wanna have some glow around the filament itself just like the one in the picture attached to this message if possible please give me some settings. thank you!
Ben van Hamelen
Re: How can i get this Light bulb effect (check the image attached)
on Jan 16, 2013 at 9:53:59 am
Probably not. But you could try emitting some particles from the wire and give them a material with lots of incandescence. I don't know if it's ever been tried before, but it could work.
Other than that you'd probably have to resort to After Effects or Photoshop.
Good luck,
Ben van H.
http://www.fireinthesole.com/
King Law
on Jan 18, 2013 at 3:28:08 pm
ok will try that see if it will work thank you!!
Scott Norris
on Jan 16, 2013 at 1:32:21 pm
I'm not a very profficient maya user, but I think I came across a texture, surfaceshader, that creates the glow you're describing.
Terry Coolidge
on Mar 29, 2013 at 8:02:12 am
"Special Effects" attributes are available for Anisotropic, Blinn, Lambert, Phong, and PhongE materials. Just bump up the "Glow Intensity" and you'll get what you're looking for. You don't need much. I usually start around .125 or .25. It starts to get pretty exaggerated pretty quickly.
