vray question
COW Forums : Autodesk Maya
Lefteris Sifidis
vray question
on Nov 28, 2012 at 9:11:13 am
i assigned a blinn for both images below:
with mental ray
and with vray
the vray render is like the white part has a different light source. why is that?
(both renders are made with nurbs > isoparm > detach surface)
Otto Lindqvist
Re: vray question
on Jan 24, 2013 at 3:23:36 am
For some reason I wasnt able to open the first file.
However try to use only VRay materials with VRay. Sometimes maya materials are not working with VRay and gives weird results like that. If you are using VRay I cant see any reason to use Maya materials. It's not too difficult to use VRay basic material. It gives you more accurate results.
So I think it's just that VRay cant handle Maya materials because it's built for VRay materials.
If it's not moving, animate it
© 2018 All Rights Reserved
