Particle instancer problem
COW Forums : Autodesk Maya
john titor
on Nov 26, 2012 at 11:29:58 pm
Hi, I'm following the maya outerspace dynamics vid. I map my asteroids onto the particles using the particle instancer option. However the expressions I create to randomise rotation and the asteroid objects do nothing. The data type is set to float as a per particle array attribute. Moreover randomising the scale makes them dissapear. How do I fix this? Thanks in advance.
Dennis Volkerts
Re: Particle instancer problem
on Apr 2, 2014 at 7:15:58 am
after creating your expression do not forget to set the rotation to your customRot in the rotation options. Had that a couple of times.
plus rotation is in degrees ---> rand(360);
or: <>
Holy creative COW!!!!
