Maya MEL Script for Region Rendering...
COW Forums : Autodesk Maya
Mike Moss
on Oct 19, 2012 at 7:43:51 pm
Hello,
Experianced in Maya and command line rendering, but need some help with a MEL script...
What i need (or see if its possible) to do is create a MEL script that will be called during a command line render.
The MEL script needs to designate the region in which the frame will be rendered.
I know this can be done simply through a command line argument...
(-reg xx xx xx xx)
But here is the reason i need it to be in the form of a MEL...
I want to designate MORE than 1 region per frame. Is this possible with MEL?
Lets say i want to region render the four corners of the image...
-reg xx xx xx xx
-reg xx xx xx xx
-reg xx xx xx xx
-reg xx xx xx xx
How can implement rendering multiple regions into a mel script?
Once i have the proper script set up i can run the -preRender flag in the commandline...
Thanks in advance!
(Let me know if i left out any helpful information...)
Mike
