32 k texture in maya
COW Forums : Autodesk Maya
Arash Entezami
on Oct 3, 2012 at 8:53:44 pm
how can I assign 32 k texture to my object in maya ?
it makes maya crash
which extention should I use to save my texture from Mari ?
I need this huge texture because one shot pan
Ben van Hamelen
Re: 32 k texture in maya
on Oct 9, 2012 at 12:16:51 pm
Are you absolutely sure you need textures that large? 32k is absolutely HUGE. 4k is usually more than enough. However, if you really need a huge texture map, try dividing it into smaller bits and applying it onto the object in pieces, if the project allows you.
If that isn't possible, include a few screenshots in your next reply so we can see what the scene looks like.
© 2018 All Rights Reserved
