problem with bridge!
COW Forums : Autodesk Maya
john damiani
on Sep 5, 2012 at 8:37:16 am
I'm following a tutorial, and in one part, its having me connect 8 faces together with another 8 faces, but for some reason, the model is twisted up.
Was wondering if anyone knew how to fix this. here is a picture of the problem
http://i87.photobucket.com/albums/k125/adecoy95/Untitled-94.png
As you can see, the lines are not connecting properly on the top and on the bottom.
Hoping someone here has a solution.
Ben van Hamelen
Re: problem with bridge!
on Sep 5, 2012 at 12:26:31 pm
Could you post a screenshot from before the bridge-operation? It's kind of hard to tell what went wrong if we only have the current situation.
http://www.fireinthesole.com/
john damiani
on Sep 5, 2012 at 1:40:48 pm
I would be happy to!
http://i87.photobucket.com/albums/k125/adecoy95/1-11.png
This is the piece before i perform the bridge operation, 8 faces on both of these pieces. i have checked and rechecked them to make sure i don't have any hidden vertices or faces (just in case).
This is the faces selected in the side view:
http://i87.photobucket.com/albums/k125/adecoy95/2-8.png
These are the parameters for the face action:
http://i87.photobucket.com/albums/k125/adecoy95/3-4.png
This is what it looks like after i perform the action:
http://i87.photobucket.com/albums/k125/adecoy95/4-4.png
This is the position of the curve:
http://i87.photobucket.com/albums/k125/adecoy95/5-3.png
This is the entire object selected:
http://i87.photobucket.com/albums/k125/adecoy95/6-3.png
I have checked to make sure they are not inside out, with 2 sided lighting, it appears to be working fine.
Thanks in advance for anything you can suggest that might fix this!
Ben van Hamelen
on Sep 5, 2012 at 2:30:24 pm
Ah, now that's something I can work with. Here are some possible fixes:
1) I didn't even know you could bridge along a spline, but it makes sense. Anyway, it looks like the curve you drew is sticking into your meshes. You should position the start and end of the curves just right before the start and end faces.
2) Another common issue is bridging with more than 2 edges selected. It gives me problems all the time. Not this particular problem though. You could select 2 edges at a time, bridge (with or without curves), skip the next 2 edges, take the 2 edges after that, bridge again, etc. When you're done, you should have a whole load of holes in your mesh. Fill hole and if necessary, split your polygons until you have nice looking geometry again. Why skip them? Because if you bridge next to another bridge, Maya won't always merge your vertices properly, which will give significant problems down the road. Try it the wrong way and smooth your mesh. You'll see what I mean. Unless you have that one flawless copy of Maya, but I doubt it.
3) Do the whole thing manually. Extrude the edges and merge the vertices on the other end. I usually go for this option, because it's easier to spend two minutes doing it by hand than spending 10 minutes trying to fix a buggy Maya tool.
4) Not a fix, but a test: start a brand new scene, create the same 2 objects (do not import them, make them from scratch) and try bridging again. If the geometry is clean and you still have the same problem, then you're dealing with a buggy tool. If the geometry is clean and it's fixed, then your previous model probably wasn't done properly.
Wow, that became quite a story. Well, either way, I'm sure one of these fixes should do it for you. I'd try 1 and 3 first. Let me know if it worked.
Cheers,
Ben van H.
john damiani
on Sep 5, 2012 at 3:16:09 pm
Well, the curve was built by Maya, not much I can do on that end.
BUT, I found a solution, it was so crazy, I made the bridge with no divisions, then I added them, hilariously this caused a bunch of invisible faces, but after re-adding the default Lambert, problem seems to be solved. a strange workaround, but it allowed me to keep the handy bridge curve!
Thanks again for taking the time to give me some help.
Ben van Hamelen
on Sep 5, 2012 at 3:27:10 pm
Ah, the invisible faces. Yet another Maya bug. Glad you figured it out.
Cheers,
Ben van H.
