Created lights appearing under defaultlightset
COW Forums : Autodesk Maya
James Paton
on Sep 2, 2012 at 2:26:20 am
All new lights I create appear under the defaultlightset in the light linking editor. Somehow a directional light I'd created a while ago is the only one not part of the set, although it was at some point.
I think it's causing problems with my light linking, because although I specify which lights are linked to objects, it seems to ignore the specification if its under the defaultlightset.
Am I lacking in some basic knowledge?
keith mcgregor
Re: Created lights appearing under defaultlightset
on Sep 12, 2012 at 9:17:20 pm
Did you break the links from the other objects? I've run into that fun one before.
-Keith
