maya render issue / banding
COW Forums : Autodesk Maya
Patrick Vaughan
on Jul 19, 2012 at 4:42:43 pm
Hello all,
Back in Maya after a 6 year hiatus with C4d. I'm getting some banding on my render with only solid material. Seems that it is a model issue not a material issue as other items in the scene with same material are fine.
Low poly or smoothed poly either way no dice. Take a look and any help would be appreciated.
Steve Sayer
Re: maya render issue / banding
on Jul 23, 2012 at 2:07:00 pm
That looks like depth-map shadow banding to me. Do you have a light with depth map shadows in your scene? Try switching to raytraced shadows and see if that helps.
Patrick Vaughan
on Jul 23, 2012 at 3:25:48 pm
That was the issue thanks!. Didn't think of that as the rest of the models seemed fine at that dmap resolution.
