scifi render
COW Forums : Autodesk Maya
Bruce Borowy
scifi render
on Jul 12, 2012 at 6:37:37 pm
I need some help with trying to get photo realistic ship render, the ship is polygon and has some rough edges and docent look quite right, and need some input,
thanks, Bruce
Eric Santiago
Re: scifi render
on Jul 13, 2012 at 2:43:07 am
an environment map will help a long way :)
Steve Sayer
Re: scifi render
on Jul 17, 2012 at 5:31:43 pm
Sorry, I missed your update on the earlier post.
How many polys are in this object? It's not always true that more polys = a better model, but in this case I feel like I'm looking at just a few dozen, which isn't enough detail to really make the object feel solid. If it's a ship, it must have all sorts of parts and pieces that come together to make it what it is. Right now it feels like a piece of folded paper, or something.
Look at some examples of other ship models to get an idea of the level of detail you need:
http://www.turbosquid.com/HDView/index.cfm/ID/503210/r/3/i/4
http://www.maximechasse.com/wp-content/uploads/2010/09/BoatWired_Big1.jpg
http://img12.imageshack.us/img12/7808/gkwire.jpg
Again, it's not the sheer number of polys that matters, but how they're arranged... create structures and details to give a sense of solidity, construction, and realism to the object. Make sure to give every surface some thickness; avoid perfectly sharp edges, etc.
Bruce Borowy
Re: scifi render
on Jul 17, 2012 at 10:11:41 pm
Eric, thanks for the input, I am using a MR sun and sky environment for this scene,
Steve, that was some really good advice and thanks for the refs to look at for my scene,
thx, Bruce
Bruce Borowy
Re: scifi render
on Jul 18, 2012 at 4:12:49 am
here is another scene of a puddle jumper trying to incorporate your input
Eric Santiago
Re: scifi render
on Jul 20, 2012 at 10:24:39 pm
not having enough angles to catch your MR env from my pov.
you can also add more detail with textures.
grunge maps do a lot to a flat object.
again Im not seeing the MR env on your latest pic.
Bruce Borowy
Re: scifi render
on Jul 22, 2012 at 7:01:56 pm
thanks for the help eric, I am using MR physical sky and sun, I will add some more textures and maps
Bruce Borowy
Re: scifi render
on Jul 22, 2012 at 11:11:38 pm
here is some more detail and lighting
Steve Sayer
Re: scifi render
on Jul 23, 2012 at 2:04:31 pm
The material on the main body still looks like a flat Lambert. Make sure it's a material with specular properties, such as Phong or Blinn. Eric's comments are all good. Make sure you map the specular properties as well as colour.
Part of the problem, I'm afraid, is that that vehicle just doesn't have a very interesting shape. That means most of the detail is going to have to be carried by small modeled details and maps.
