Shader brighter towards edges
COW Forums : Autodesk Maya
Stephen Grimm
on May 17, 2012 at 10:51:39 pm
I'm relatively new to Maya, so this may be a simple answer.
How would I go about creating a shader that gets brighter towards the edges of an object. I'm not talking about an xray that gets brighter towards edge based on how it's viewed. More like a toon shader that gradates brighter towards hard edges.
Steve Sayer
Re: Shader brighter towards edges
on May 23, 2012 at 2:36:49 pm
It would probably be less trouble to just texture this, rather than trying to create a shader to do it. Just paint a 'brightness map' that ramps up towards the edges you want to highlight.
Or you could experiment with the existing toon shaders... they are capable of highlighting hard edges, though I don't know how easy it will be to turn that into a wide gradient instead of a hard line.
Stephen Grimm
on May 23, 2012 at 6:19:57 pm
I was afraid of that. I'm not the best UV mapper...
Thanks for responding though.
