Can't figure out how to select multiple edges
COW Forums : Autodesk Maya
Kaitlyn Gales
on Apr 4, 2012 at 3:26:22 pm
I'm currently using Maya 2012
I've been using it for about 7 months now and I used to be able to double click an edge and it would select a line of edges.
However, now when I try it it won't work.
Is it possible I just turned off a setting?
Ben van Hamelen
Re: Can't figure out how to select multiple edges
on Apr 5, 2012 at 10:07:38 am
Is this in one specific project only or does it happen in a brand new project as well?
If it happens in a brand new project as well you could double-click your selection tool and reset its settings. That might fix it. Otherwise there is a submenu on Selections in the Preference Window.
Either of those should fix it, I think.
Regards,
Ben van H.
http://www.fireinthesole.com/
Kaitlyn Gales
on Apr 6, 2012 at 3:55:55 am
I got the problem halfway figured out by chance, I think. I just did a "save as" and it fixed most of the problem. However, now when I make an extrusion (in the same window or a new one) I can't double-click ad select all the edges. This isn't as much of a problem as before, but it would still be nice to know how to fix it for future reference.
Thank you for your insight from before!
adam karapetyan
on Apr 10, 2012 at 11:31:50 am
I do agree with Ben van Hamelen. It happen several time at but nit regularly, it's a problem of application.
Adam K - The Animationspot - A leading [url=http://theanimationspot.com/] Animation Company [/url] in USA. For more information visit our site.
Adam K - The Animationspot - A leading animation company in USA.
