C4D with Maya
COW Forums : Autodesk Maya
Sala Sultan
C4D with Maya
on Mar 17, 2012 at 5:05:42 am
Hello there! Another quick question tho I know the answer won't be that easy
I'd like to move objects from C4D to Maya, I tried exporting it as FBX and indeed I could import it to Maya but the textures didn't come through even though in the export options I check textures..
How can I export objects from C4D to Maya with the correct UVs and Animation? Or just UVs
Thanks in advance
Sala
Ben van Hamelen
Re: C4D with Maya
on Mar 18, 2012 at 8:44:54 pm
That's interesting, I actually work the other way: Maya to C4D.
You're correct, FBX does not transfer textures or does an extremely bad job at it. I think .obj does, but it doesn't do it flawlessly. That's why I prefer to texture in the same program as I will render in. It always requires extra texture-work otherwise.
I'd give the .obj export a chance.
http://www.fireinthesole.com/
Sala Sultan
Re: C4D with Maya
on Mar 19, 2012 at 3:49:16 pm
Hey thanks man
I tired the obj.. Didn't work out, the textures didn't come through
But thanks!
Sala
