Textures directory re assigning
COW Forums : Autodesk Maya
Dario Antepara
on Mar 6, 2012 at 11:56:33 pm
I received a big scene with 238 textures.
Each of those textures have a directory path, ( Like Y/hard drive/ etc/ etc/ etc/ texture). That is the scene creator's path... I don't have a similar configuration, no "Y" hard drive.
So I put all the image textures in a single folder in my hard drive. Is there a way to tell the hypershade to go look at that single folder for the textures?
Otherwise I'm gonna have to reload all those textures, one by one and re direct them to my textures folder.
Stuart Christensen
Re: Textures directory re assigning
on Mar 7, 2012 at 7:36:20 am
Hey Dario, not sure if this would work for you but here's a script that sorts that type of stuff out. Check it out! You may need to make a custom script for "special needs" but if your files are all in the relative same path it may do the trick.
Hope that helps!
© 2018 All Rights Reserved
