Render not saving the alpha
COW Forums : Autodesk Maya
Dario Antepara
on Feb 24, 2012 at 11:41:20 pm
Got a character fully rigged, ready for me to animate.
When I do a test render, it renders beautifully, I see all the colors.
But when I check the alpha, only the eyes are saved as alpha. The rest of the body renders transparent alpha.
What part of Maya can I look into to fix this?
Dario
Steve Sayer
Re: Render not saving the alpha
on Feb 27, 2012 at 2:40:36 pm
Hmm, that's odd.
Select the material node(s) applied to the surfaces of the character, and check the 'Matte Opacity' section, maybe. The mode should be set to 'opacity gain,' and the slider should be at 1.
Hope that helps.
