Why this MEL scipt miss to work properly?
COW Forums : Autodesk Maya
Mostafa Talebi
on Feb 8, 2012 at 8:40:04 pm
Hello Everybody
I have written down this MEL script which is to do a very simple task:
Set Attribute of the selected object to 0(not freeze it, only turn it to 0)
It does not pop up any errors but only doesn't produce any result at all.
The code:
string $sel[] = `ls -sl`;
for ($each in $sel)
setAttr $each.rotateX 0;
Steve Sayer
Re: Why this MEL scipt miss to work properly?
on Feb 10, 2012 at 2:52:20 pm
You can't just stick an attribute name after a variable like that. You have to tell Maya to add them together. So $each.translateX won't work, but ($each + ".translateX") will probably work.
Mostafa Talebi
on Feb 10, 2012 at 9:11:11 pm
I went on like expressions. THANKS very much;
your help much appreciated.
Steve Sayer
on Feb 14, 2012 at 10:03:02 pm
You're very welcome, Mostafa!
